Hi all,
I’ve seen some other PI40 threads on here that were similar (stove will ignite but will not stay lit) but in my case there are no red error code lights as described in the manual: (broken link removed to http://ironstrike.us.com/system/document_files/files/000/000/372/original/900139-00_B_IRN_PI40_Pellet_Insert_EN_IICO.pdf?1534458108)
Instead, in my case the ready light will flash green when this happens. If I catch it on time I just turn the knob to OFF and then back to the heat level I want and it will continue on as normal.
I cleaned the POF switch and also tested by bridging both the POF and the convection fan switch but it made no difference. Since it’s not throwing any of the red light errors as described in the manual I am not sure what this could be.
I recently bought the insert used locally and installed it with flex liner up to the top of the chimney and this issue has occurred since the start (only used about a bag of Somersets thus far)
thanks in advance for any suggestions and let me know if any other details are needed.
