Last year was my first year using a woodburner in my house. However, as a child I grew up with a woodburner providing heat in the winter. Ok...in my house everytime it gets really cold out...in the 20s or below...I get really bad window condensation. So bad that the water droplets actually roll down the door or the window and then down my walls. My windows are old single pane and the house was built in the 50s...I suspect that the house has limited insulation. This only happens when I use the woodburner. When I use my oil furnace I experience no window condensation. Has anyone else experiencing this? Is it because the woodburner is a drier heat and it's not an equally distributed heat? The woodburner is in the basement and the heat rises through floor vents and from coming up the stairs. Last night the house temp was 75-76 degrees and over night it dropped to about 66 degrees.
