Interesting phenomenon for your reflection.
Two Wilo Eco Stratus f16 smart pumps, installed on my system 3.5 years ago and running non stop(as they do), decided to rotor lock Sunday morning.
All zones calling, primary loop pump running circulating 150f water and the Wilos are dead stopped with mixed down 110f feeds and with power supply ok.
Also adjusted speeds for kicks...no go.
No air, purged both pumps/legs, loop, (even though both feeds simultaneously locked due to air would be pretty improbable mathematically) and pumps still locked.
Finally went "high tech" and shut whole system down(reboot) and voila..they magically run..
According to pump specs & Wilo tech support, only 2 factors rotor lock these pumps:
a) 230f>
b) voltage irregularities....hmmmm
In said case:
a) Impossible in my system and exact circumstance, even though when they heard "wood boiler" they assumed that to be the cause....I was not impressed or amused, given the data I gave them regarding my system.
thus
b)...but nothing else was affected in the system, no power outs, no shut dns, ...so what gives?
End line from them...they are stumped and the event is going to higher ups for answers..to let me know asap.
Any thoughts or input?
see attached pic, the pumps are vert stacked side by side
Take care
Scott
a) 230f>
In said case:
thus
Take care
Scott
