i have been buying my wood for 2 years now.....but i wanna cut it bad..u guys have put this bug in me.....my problem is all i have to drive is a chevy cobalt...will this car pull a trailer with firewood loaded on it?
MarkinNC said:No, I don't think you can safely pull it.
You can probably get into a used truck for what it would cost to replace your transmission. Log loads are a good idea in the interim.
KarlP said:I've hauled far more wood with a Corolla than I have with a pickup truck. Never had any problems. Yes, the transmission will downshift so the engine is in the power band. Some people might think that is the point of having a transmission. ;-)
DanCorcoran said:It's not getting the load moving that's the problem, it's stopping it. The brakes are the limiting factor. If your brakes aren't engineered for the load, then you are endangering yourself and others on the road.
Bocefus78 said:Will it PULL it? 1 word answer, yes. If you choose to, please you tube it.
Will it STOP it fully loaded, or, for that matter, overloaded as alot of us do? No.
You should be more concerned with stopping it. That car has brakes the size of, well....there small. Research some green wood weights. As stated before, trannys arent cheap, neither are lawyers, hospitial bills, etc.
In other words, go find ya a rusty but trusty truck and then save up some coin for a trailer.
