ever since i drained my oil boiler to do my plumbing for the wood boiler, the pressure relief valve on the oil boiler has been pushing a trickle of water out every now and agian. enough that i have to keep a bucket under it. when i filled my wood boiler i did replace the valve. so i am on my second relief valve with the same exact results. whats up with that? the pressure reads on the gauge at about 15 lbs., on the wood boiler it reads closer to 20 lbs. it does it all the time, whether its hot or cold, circulating or not, wood boiler off.....etc.... you know the definition of insanity, right?
