Why is choosing a new insert so hard? Why must one research til their eyes burn? Why why why???? Jus venting a little, I was dead set on what new insert I wanted then the more I'm on here the more stoves I wouldnt mind trying!
Todd said:The BK insert is the same stove as the freestanding Princess without the legs. You should get same burn times. A good way to stack a lot of wood in a small space is a Holtz Hausen. Couple of these will get you a couple years ahead and good dry wood.
CodyWayne718 said:Todd said:The BK insert is the same stove as the freestanding Princess without the legs. You should get same burn times. A good way to stack a lot of wood in a small space is a Holtz Hausen. Couple of these will get you a couple years ahead and good dry wood.
I ain't got the patience to be stackin like that! :coolsmile:
BrowningBAR said:CodyWayne718 said:Todd said:The BK insert is the same stove as the freestanding Princess without the legs. You should get same burn times. A good way to stack a lot of wood in a small space is a Holtz Hausen. Couple of these will get you a couple years ahead and good dry wood.
Instead of a straight line, it's a circle. Where's the patience come in? Plan a little bit and your storage space is solved.
CodyWayne718 said:
Franks said:CodyWayne718 said:
"Why is it so hard?!?!?!?"
BrotherBart said:But a great place for a party.
CodyWayne718 said:Why is choosing a new insert so hard? Why must one research til their eyes burn? Why why why???? Jus venting a little, I was dead set on what new insert I wanted then the more I'm on here the more stoves I wouldnt mind trying!
snowleopard said:CodyWayne718 said:Why is choosing a new insert so hard? Why must one research til their eyes burn? Why why why???? Jus venting a little, I was dead set on what new insert I wanted then the more I'm on here the more stoves I wouldnt mind trying!
because there are so many variables, and because you want to make the right decision. Feels like running a computer program a zillion times, shift a comma here, add a what-if there. It will be worth it all a year from now--it's just a miserable process to be going through. Kinda like childbirth just before you puke, if that analogy is helpful; it means that progress is afoot. Expect some action here shortly.
BK Princess seems like a can't-go-wrong choice if you are forced by circumstances or a wife-gone-nuts-from-hearing-about-it to choose.
Of course, there's always the Hearthstone insert . . .
BeGreen said:BrotherBart said:But a great place for a party.
LOL :lol: I hadn't seen that one. :lol:
