I had buried a post very similar to this one inside of another thread but thought I'd bring it up in it's own thread.
Iron & Oak vs. Speeco???
I hear the I&O are great splitters but I’ve never seen one except via images online. Looking at the specs the are not really that much better than Speeco’s specs but I&O demands a much higher price. Here’s some points that I see…I'm primarily looking at the 22-ton units.
* It looks like the I&O engine is an upgrade over the Speecos.
* The I&O has a smaller dimensioned beam and uses a clamp on wedge (good/bad?...apparently most manufacturers use this style).
* The I&O has no built-in log-dislodger ($85 extra).
* It looks like the I&O has a larger hydraulic fluid reservoir.
* Both machines have roughly the same cycle time.
* The I&O outweighs a Speeco 25-ton unit (couldn’t find a weight for their 22-ton) by 50 pounds…and the 25-ton Speeco has a 4.5†cyclinder compared to I&O’s 4†cylinder…I state this difference in cylinder size to show that the I&O’s heavier weight must be in framing, beam, fenders, etc.,.
Anyhow, somebody want to point out what makes such a difference in price between the two?
Thanks!
Ed
Thanks!
Ed
