3 x 16" = 48" = 4'Risser09 said:It sucks because most people cut wood to 16" lengths. If you stack wood in 2 rows you would have 32" worth of depth to your pile. It would then take 6' of height and 8' of width to complete a full cord. This is how I stack, because I cut to 16" lengths.
2.6666666666 x 6 x 8 =128
Don't you think the imperial and US measuring systems go from bizarre to completely ridiculous. I mean why 128 cubic feet anyway?Adios Pantalones said:I believe that the etymology of the word has to do with a cord that was used to measure out the stack. Probably a 4' cord.
bokehman said:...Don't you think the imperial and US measuring systems go from bizarre to completely ridiculous?
bokehman said:Don't you think the imperial and US measuring systems go from bizarre to completely ridiculous. I mean why 128 cubic feet anyway?Adios Pantalones said:I believe that the etymology of the word has to do with a cord that was used to measure out the stack. Probably a 4' cord.
Here firewood is sold by the kilogram. You reserve it in the spring and then late summer or early autumn you go to the wood yard and select the pieces you want. Take a maul and break open a few splits to measure the water content and then make a pile which the guy drops at your house. It's split in the spring so it's almost seasoned by October (no rain and desert sun).
Would we be shortchanged when we turned the clocks back??fossil said:bokehman said:...Don't you think the imperial and US measuring systems go from bizarre to completely ridiculous?
Yes. I think everything should be based on the distance travelled by light in absolute vacuum in 1⁄299,792,458 of a second. Rick
It's just a datum. The best thing about metric is easy conversion of units and no need for adding strange constants when doing calculations. It's so simple. Water, 1ml = 1cc = 1 gram; 1 litre = 1 kilo; 1000 kilos = 1 ton; etc. Freezing point 0C, boiling 100C.fossil said:bokehman said:...Don't you think the imperial and US measuring systems go from bizarre to completely ridiculous?
The distance between Yeti’s heel & big toe are in there somewhere too, I think. Rick
I have on-site precisely 13.278 cords of mostly split & stacked firewood. Margin of error is +/- 2.362 cords. Rick
bokehman said:It's just a datum. The best thing about metric is easy conversion of units and no need for adding strange constants when doing calculations. It's so simple. Water, 1ml = 1cc = 1 gram; 1 litre = 1 kilo; 1000 kilos = 1 ton; etc. Freezing point 0C, boiling 100C.fossil said:bokehman said:...Don't you think the imperial and US measuring systems go from bizarre to completely ridiculous?
Being a Brit I was brought up imperial. When I was a kid there were 960 farthings, 240 pence, 20 shillings or 4 crowns in a pound. There were even a 3 penny and 6 penny coins. Then the currency was changed to 100 pence in the pound and the shop owners made a killing.
LEES WOOD-CO said:I believe the measurement of a cord goes back to the day 40+ years ago when pulpwood was cut 4' long. Back then it was all hand loaded on trucks . I think the machinery in the paper mills back then were only capable of handling the short lenghts .A logger would get paid by the 4' cord when delivered to the mill.
