Why doesn't water boil in my tea kettle?
kevinmoelk
This may seem like a very dumb question, and I'm sure there is a simple explanation, but...
I recently found an old tea kettle I have and filled it up with water and placed it on the stove which normally reads 500-600 degrees fahrenheit. If water boils at 212, then why does the tea kettle only steam and not boil?
-Kevin
Is the top on the kettle?
As Dylan says, the heat is escaping. Either from the steam itself or from radiation. Try closing all the holes where the steam is escaping.
How hot did you want your tea? :bug:
Matt
or- how thick is your kettle?
I have a lattice top steamer that almost never boils, but the aluminum tea kettle from grandmoms house boils almost instantaniously. also noticed that putting the kettle right up against the single wall pipe heats it way faster than if just left on the stove. be careful, my kettle left a rust ring..
:bug:
Paging Mr. Darwin... Mr. C. Darwin... please report to Mr. Wrenchmonster's house... Darwin to Mr. Wrenchmonster's house.
Does health insurance still cover shrapnel wounds?
-- Mike
Cast iron kettle and it only boils when the stove is running too hot
I do have to refill it every day though so I know its working.
http://www.foodnetwork.com/food/recipes/recipe/0,1977,FOOD_9936_16494,00.html
*Note: For Oolong and Green tea, water should simmer at 200 degrees F. and 180 degrees F.
*For Irish and English tea bring water to a full boil.
*Black tea should soak for 3 to 5 minutes. Oolong tea should soak for 4 to 7 minutes. Green Tea should soak for 2 to 3 minutes.
I struggled with the same issue. I think part of my problem is my stovetop surface is slightly textured, inhibiting heat transfer. I did think of trying a cheap thin stainless or aluminum kettle but haven't picked one up yet.
Okay, simple enough explanations.. thanks guys. I think it has to do with my tea kettle design. It's an antique, very large, holds lots of water, and most importantly the hole to fill up the water is 3" across with no lid. It does "simmer" where I can see tiny little bubbles along the edges inside, but no boiling.
I have a more modern tea kettle that I actually use for potable water that is far more enclosed. It's on the stove now and we'll find out if it boils.
-Kevin
For Christmas this year I was given an LL Bean stovetop kettle with a lid on it which is porous with a graphic pattern of leaves on it. I've been using it (as opposed to a 1lt aluminum pot I'm not using for cooking) for a few days now and it never boils cause of the open air design I presume, it just generates steam as per the intent.
Jay
MrWrench:
The water in your kettle will never boil at 212*F if:
1. Enough heat is not applied to the kettle over a long enough time
2. The kettle allows heat to escape faster than it is applied
3. The kettle is insulated well enough to keep heat from water
4. The water has sufficient particulate matter to raise its boiling point
5. The atmospheric pressure in your particular location varies significantly from that at sea level
6. The water can escape from the kettle through holes before it reaches its boiling point
7. The water in the kettle already exists as steam
8. You are watching it.
And, you may want to check to see if:
1. Your kettle has few enough holes, in the proper places
2. Your kettle has accumulated significant "scale" from your water being "hard"
3. Your heat source is sufficient
4. Your thermometer is accurate
5. Your really need to boil water in the first place
Aye,
Marty
No Dylan, not high school science.
But I have looked at things with a scientific curiosity my entire life.
That explains what I did teach: "The Biology of Epidermal Repair" at The Bikini Waxing Institute of South Miami, 1972 - 1992.
Aye,
Marty
it's because it's a tea kettle and you have water in it..if you put tea in it..it would boil
operator error
There is not enough heat (energy) being applied to the system. There is an enormous amount of energy that must be constantly supplied to the system After the water reaches 210 F. I think it is around 540cal/ml.....if I remember correctly.
Mike
There is not enough heat (energy) being applied to the system. There is an enormous amount of energy that must be constantly supplied to the system After the water reaches 212 F. I think it is around 540cal/ml.....if I remember correctly.
Mike
Try wrapping the pot in foil. That would stop some of the surface heat emission (good reflectors make bad emitters, and vice versa.)
If that doesn't work, try 12" R15.5 glass fiber insulation:)
