By way of example, my house before renovations was rated at 8 air changes an hour ( 192 complete changes per day) and after air sealing and new windows, it dropped to 3.8 air changes per hour (91.2 per day).
Oconnor, I can't help but think you're mislocating a decimal point or two. The level of air change used internationally as the norm in terms of analyzing the success of various ventilation schemes is 0.3 air changes/hour, or 7 air changes per day.
You're in Canada, so let's take a look at the numbers from a 1989 Canadian survey of 200 homes across the country I found at
http://irc.nrc-cnrc.gc.ca/pubs/ctus/14_e.html
In that survey, more than 70% of the homes surveyed evidenced an annual air leakage rate of less than 0.3 air changes/hour, or 7 air changes per day, which is right in line with the international norm.
You're describing your house, after air sealing and new windows, as having
nearly 13 times that air leakage rate. If that is indeed the case, the additional 0.2 air changes/hour created by a woodstove does indeed look small.
If we move your decimal point over one place to .38 air changes/ hour, which seems a more reasonable level for a two story home built in the 1930's, the impact of the additional 0.2 air changes/ hour created by your woodstove looks far more significant: if fact, it constitutes an increase in hourly cold air infiltration of
over 50%. In a typical home with an air leakage rate of less than 0.3 air changes/ hour, a woodstove installation with a 25 cfm outflow would constitute a
67% increase in cold air infiltration.
Check your numbers and let me know what you think.
