Hey everyone. I've been searching and reading all I can for tips and instruction on how to install a wood burning stove in my 24' x 30' detached garage.
I have a good size AURORA stove.
My plans are to keep the stove 5-6 ft from the back wall.
I was going to put a '90' on the back of the stove and then put a 4-5 ft. section of black pipe. Then another '90' and run a few more feet of stove pipe that I will connect to some double or triple wall pipe to go thru the CELOTEX wall and wood siding , which make up my garage walls.
Once I'm outside the garage about 2-3 ft., I was going to run black stove pipe straight up about 10-12 ft to get past the peak of the roof.
Can I not use stove pipe as my chimney, with a cap/rain shield on top of it?
Also, could I not just run the double wall pipe thru the wall and let it extend a few feet on the outsdie and turn it upward for 1-2 ft and be done with it, instead of running a stack/chimney all the way up?
Thanks
Thanks
