Built house in 1997, gave mason spec for Quadrafire 3100i that we moved from old house to new house to use while building fireplace...said it has to be big enough to fit this stove...he built it...you guessed it...big enough for that stove...but NOT for what we now want to replace it with. :-(
Looked at a PE Alderlea T5 insert...wanted that...sorry...no can do...looked at PE Super...ugh..again...
PE Super is 21.5" back width, not counting the leveling bolts from their specs...and 18" from the surround to that point. I'm about 0.75" short...but the bolts could still be a problem since I don't know how they factor into that 21.5" spec.
I looked at the Regency I2400...and the dimensions for that are 23.25"W and 17.25"D...seemingly a non-starter...but the shop had the I2400 out where I could see it versus the PE where it was slid into a false brick facade.
I did some measuring...the surround on the I2400 projects backwards from the front of the stove???? I put a box on the back of the stove simulating it being slid into a firebox and then measured from the rear of the stove to that point...16.5", NOT 17.25D"...
As luck would have it, I had a box that was 22"W....slid that into the firebox...hmmmm...the first line is 18" for the Super and then 17.25" or so for the Regency. IF I only had to slide the Regency in 16.5"...I think I have the 23.25"...for the leveling bolts...the width on the back looks okay...even with my encroaching firebox walls at 22" high.
I need to measure twice and cut once....or maybe measure another four times...but it has me thinking...
A local dealer has a Quad 3100i ACT (must be a leftover for quite a while), the Quad 3100i ACC would do the trick as well.
I have issue with pulling out the Jotul C450 to get it forward and clear the width and the exhaust and lentel (spelling?) bar.
Hearthstone Clyde might fit, need to get specs.
Enviro Venice or Kodiak 1200 would fit, but not the 1700.
ALL of the stove EXCEPT the Regency I2400 have clearance issues to surround...it is STUPIDLY close...and even the amazing low number of the Regency would only clear with less than 0.25". Yes, I self installed the quad in 1997 and didn't realize it was too close on clearances...but in my defense, I had a mantle shield from my old house...so I would need to rework the surround...which would be fine by me, I am tired of it.
If I can get the Regency to work, and I could just pull it out another 0.25 to 0.50" to get it worse case, I'm tempted to go that route, but I'm looking for people to comment on what I've typed....am I trying too hard to force the I2400?
I thought the Kodiak/Venice 1200 wouldn't work well...but the Quad has worked well...and if 1.9cu ft worked for us, 1.85 should?
We supplemental heat...the floorplan is quite open on the first floor for family room to kitchen, hallway, and it's cooler in the living and dining rooms, but still fairly comfortable. Figure 73-76 degrees in family room with ceiling fan running and 68 or so in the dining room. We do NOT even attempt an overnight burn with the quad...5pm to bedtime and weekends 7AM to bedtime, about 25' chimney, 8' in garage, 8' in space above garage (not outside), and 9' outside, 6" liner, no insulation, and I've learned now, the quad didn't have a block off plate at the damper, but it is sealed at the top....oh and we didn't use an fans with our quad, just ceiling fan and convection/radiant.
Quad is from 1992...it's tired....bricks, baffle, door glass hazy (might have overfired it a few (+ a couple) times since new...oops), gasket, and blanket all need replacement.
Thoughts? Comments? Rankings? Like I said, tempted to go Regency, after that, unsure, the Kodiak/Venice might work just as well as the old quad, and we could get the 3100i ACT or a new 3100i ACC, but kinda nervous seeing a pic of a cracked secondary manifold with a crack in it...and my friend having the EXACT SAME crack in his 3100i ACT. Maybe it's unrealistic to think we could get the same service we got from our beloved Quad.
Oh...and I haven't seen a BK Princess Insert at a dealer...yet! ;-)
Thanks!
![Who wants to play devil's advocate to my thinking on insert replacement? Who wants to play devil's advocate to my thinking on insert replacement?](https://www.hearth.com/talk/data/attachments/141/141102-b1336b780c3ee40a1b559c0c6c67edd0.jpg)
Thanks!
![Who wants to play devil's advocate to my thinking on insert replacement? Who wants to play devil's advocate to my thinking on insert replacement?](https://www.hearth.com/talk/data/attachments/141/141093-dea09cc5bc82ae99dcd14500b40a0598.jpg)
![Who wants to play devil's advocate to my thinking on insert replacement? Who wants to play devil's advocate to my thinking on insert replacement?](https://www.hearth.com/talk/data/attachments/141/141099-a9355c0bcea4abc440b1df407a78d416.jpg)
![Who wants to play devil's advocate to my thinking on insert replacement? Who wants to play devil's advocate to my thinking on insert replacement?](https://www.hearth.com/talk/data/attachments/141/141100-1fdd251c86982956a4eaf92ca7e99bc3.jpg)
![Who wants to play devil's advocate to my thinking on insert replacement? Who wants to play devil's advocate to my thinking on insert replacement?](https://www.hearth.com/talk/data/attachments/141/141101-6effbe1c0090e46ccec27ce8ec2e1b95.jpg)
