Ok, I wanna build a hearth. (for under my hearthstone phoenix) I need an R-1 factor. I know my hearth pad dimensions so that ain't the issue. A couple things....
1. The finished hearth will be surrounded and capped by mortared brick. (brick r = .2)
2. If I use durock, it looks like I'll need at least (3) half inch sheets thick. ( 1/2 inch r = .26)
So, .26 x 3 is . 78 plus the .2 brick gives me and r of .98.
I would likely use 4 sheets of half inch durock as that brings me well above 1.0 r factor and also is the approximate thickness of a course of brick....so 2 inch of durock, capped by brick, and surrounded by 2 courses of brick. (r of this setup would be 1.24)
My question is this, how to attach the durock to a 3/4 inch Advantech OSB sub floor?, and each durock layer to the next?
Could I just lay it in there and mortar brick on top?
Do I have to tape the seams, or can I just stagger them?
Now, on another note, is it true an 8 inch hollow core block will give me a R-1? If I lay those block with the solid side facing up, the hollow core running horizontal, and brick the top and sides,
I'd have a raised hearth yes?
This would give me an r factor of 1.2 yes?
Would I have to mortar the block or could I lay them in loosely side by side?
Nobody, and I mean nobody, has been able or willing to tell me how to do these things, that is why I am posting these two possible hearth scenarios here
thanks,
Brad
thanks,
Brad
