What model of Whit. There is lot of us owners of them here on this site with some great electrical knowledge of them. Bo, from Denmark
I was one of them as I found the posting. Still think the stupid proof of fire eye is the problem. Without the circuit being made the stove thinks no fire so it starts the shut down sequence. Yellow wires go to it.Can you get to them and disconnectect the wires to the eye and join them together to test? The stove should stay running then.
I just have to get up every 10 minutes to restart it.
A very precise way to prove that it is a dirty photo eye that is making your Whitfield shut down, is to measure the exact time from you push the start button till the stove shuts down.
Now, you say 10 minutes in the quote above, but isn't this just an estimation? The start up delay in the control board allowing the stove to warm up and get a stable fire is exactly: 14 minutes and 15 seconds. If you have a cell phone with a timer/stop watch ( I'm sure you have ), the timing test should be easy to make.
Those 14 minutes and 15 seconds could be considered a reliable fault code, so if you hit this exact time, we know for sure that your photo eye needs cleaning, adjustment or replacement.
Looking forward to hear your result. Good luck and take care.
Bo
Should till it faults.
Bo
Considering the tolerance of the involved electronic components on the circuit board, we may definitely conclude that the photo eye is the culprit.14 minutes and 25 seconds. Is that close enough?
Bioburner's suggestion to insert a manual/external bypass switch will give you a stable heat source, and from what I read about the tough winter temperatures you have over there, this will be strongly needed.What do we do now?
Hobokenkitchen, I've moved the Whitfield segment to a new thread. It will be much easier for Whitfield owners to find in the future if they are having similar issues.It will probably be easier for us to get to the bottom to the Whit than the Quad![]()
When things warm a bit end of week I'll get to the stove and shoot a couple pictures of the wires and where to mount the proof of fire snap switch.
Thank you for digging that up. Saves me a trip in the cold out to the shed. -6FSome months ago Don2222 made a very thorough and detailed thread on how to make this permanent bypass of the photo eye. His thread can be found here with pictures and all:
https://www.hearth.com/talk/threads...ery-anyone-try-this-see-pics-it-works.132882/
Or the warehouse was full of the blower assemblies and used them till they are gone. Happens all the time.The fact that there is a hole in the exhaust for the thermo disc for the eye bypass still in the stove
I recall, 15+ years ago, Whitfield did send a new/alternative fire/photo eye procedure. I guess you could do an Internet search and see if you can find one. My recollection is that it was a straight forward project; had to drill one hole, relocate the wiring, re-caulk the metal shroud in the pellet bin (I remember this because I had to get the high temp red caulk and I see it when I load the bin). I don't remember if they sent a new eye or if I used the original one and just relocated it.
