Whitfield renaissance ww1
Geopoly
11
Vancouver
I’m hoping someone could post a picture of the inside of there pellet stove mine has an air wash system with no gasket on top of the glass is this normal? I get smoke coming out of that gap?
If your combustion fan is working there should be no smoke coming out at the Glass
When was the last time the stove was cleaned from air intake
to exhaust termination? Sounds like it need a good cleaning
Look at cut away on page A pipe connecter clean out and heat exchanger cleanout
also clean the burn pot and check that all the holes are open. Also, read page A1
Cleaned it all out tried without gasket on top of glass and smoke filters out then tried with gasket on top and fire eventually just died out and smoke was seeping through the door gasket which is brand new
Read page 4 of the manual. Now that is interesting
What is the serial number of your stove?
Read pages 18 and 18a which type of stove is yours
by serial number
The serial number will tell if you have a natural draft stove or a forced draft stove
before 3608 is natural
after 3608 is forced
If before 3608 you may or will always have a smoke problem
Well, the stove is 34 years old makes a nice conversation peace!!
