I just moved into a new house over the summer and it had a pellet stove insert (begin my obsession with pellet heating!). As far as I can tell its a Whitfield Quest WP4. The number under the pellet door is wh-q 28975. The previous owner said it is a 1999 but I think it might even be older.
At first it would shut off after 10 minutes of running so some helpful searching on the forum caused me to replace the low limit switch. Now electrically it works perfectly.
Couple things I have noticed. The damper even at the very lowest setting seems to bring a ton of air into the burn pot. I usually have to run it on the lowest damper setting even with the highest feed rate. Turning it any higher shoots half burned pellets into the side ash trays. Is that normal?
Also I seem to get a "dead" area in my burn pot towards the front of the ultra grate after running for more than 8 hours. I scrape it and it just reforms in another 8 hours. I am using maine woods pellets. I am not giving it enough air to the burn pot?
One last thing. I have a 1600 sqft cape from 1950 that is far from tight. When its over 35 the stove can crank the whole house. Below freezing it can't keep up at all. Does anyone know if this is too small of a stove for this house? I love love love the manual aspect of tuning the Whitfield and am wondering if I should consider looking for a bigger Whitfield insert on CL.
Any help would be appreciated for a pellet newb![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
