Hello
This is a 1994 Quest Plus. The exhaust and fire box and exhaust blower was clean but pellets kept building up in burn pot until fire went out. It would not work on heat level 2 or 3 anymore. On heat level 1 with the damper open all the way it worked but the glass and walls in firebox got black with soot real quick! Just not enough air to burn properly.
So I went in and drilled 2 cleanout holes in the right side of the stove. The holes went into the ash chamber behind the fire wall that is otherwise incassable. Then a Stainless Steel self tapping screw is used to seal it.
The area up top on each side of the heat tubes is the only opening where the hot air goes into the back chamber and these opening were constricted from build up of ash and white calcium deposits.
Has anyone seen this problem?
A 150 PSI compressor blasted the back chamber clean and blasted the heat tubes clean in the fire box.
Then a high current 1.75 amp exhaust blower was installed on the 7" mounting plate with a 5 inch double paddle fan bladed. The blades and hub were sprayed with "Dry Moly" to give a nice protective coating.
No more pellet pile up!
See pics
Pic 1 - High current 1.75 amp open frame quiet blower
Pic 2 - 5" Double paddle blade to keep ash from forming a mound under the blades and keep air flowing better.
Pic 3 - Drill out cleaning holes - 1 close to the top and one close to the bottom in back of the fire wall
Pic 4 - blasting out with a compressor
Pic 5 - Control Panel set at 3 heat level and 3 room blower speed
Pic 6 - startup flame
Pic 7 - run flame
Pic 8 - stove with fire
Pic 9-10 Flame on heat level 3 - embers fly and pot is not building up
See pics
Pic 7 - run flame
