I just moved into a new home that im renting and it has a Whitfield pellet stove. It didn't work so I messed with it a little and found that the auger motor was bad. I've replaced that and for about a month it worked great! Until, one day I woke up for work and the stove was off. I went to turn the pellet stove back on and the auger light, instead of blinking, stayed on constant and the motor shaft had slipped out of its hole. So I pulled off the augor motor again to see if it was still turning while hooked up to power without any resistance and wasn't moving. This augor motor is brand new. Is the anyway it could have already went bad or is there a switch it tripped that wont let the augor turn on???
Any help would be appreciated
