Whitfield/Lennox Traditions T300P
mrgraphixx
1
NJ
My stove starts fine, but when it goes from start-up to regular burn mode the pellets stop feeding. I checked and cleaned the photo-eye, which was filthy, checked and cleaned the pressure swith, which was fine, cleaned the stove and checked the flue.
I am starting to think I have a bad high limit switch.
Where is it, and can I jumper it out somehow to see if that is my problem ? The only way it stays lit is if I manually feed pellets into the burn grate. Blowers work fine, it is the auger that stops working after the start-up cycle
