I have a whitfield stove, advantage II, New bushing, motor good ,but auger keeps jammimg. what is wrong?
Wood Heat Stoves said:Sounds like a bad auger motor......
rhatch7205 said:shouldn't I be able to turn th auger by hand with a handful of pellets? I can't, it jamms
Ibjeepn said:Did you ever find or fix the problem ? I have the same exact problem with mine now. Nothing wrong with the bushings. The motor removed. no play side to side.The auger turns freely by hand.... Add a few pellets and it jams instantly. Yoi !
Its a new motor. it turns fine. The motor is disconnected. Completely of the auger alltogether. When i put in a couple pellets and turn the auger by hand. It Jams up. The same way as when the motor mounted on.Wood Heat Stoves said:Ibjeepn said:Did you ever find or fix the problem ? I have the same exact problem with mine now. Nothing wrong with the bushings. The motor removed. no play side to side.The auger turns freely by hand.... Add a few pellets and it jams instantly. Yoi !
sounds like a bad motor
(broken link removed to http://woodheatstoves.com/whitfield-pellet-stove-auger-motor-troubleshoot-replacement-p-12787.html)
scroll down page for video
May have it ! Gotta get it back together and give it a whirl !Ibjeepn said:I'm going look at it today. Now, that the Christmas holiday has passed. I'll let you know what I find.
