Hello Everyone,
i purchased a used whitfield advantage 2t stove installed it and it works great. i wanted to upgrade the old thermostat that came with it (probably the original) so i did some research and found that a standard millivolt thermostat should work. i purchased a skytech 3301p thermostat and hooked it up. the stove would not respond to commands from the reciever. i disconnected the reciever and the stove went into pilot mode. connected the reciever back to the stove and the stove turned into the "on" position. however it still would not take commands from the transmitter.
i then pulled the reciever off, grabbed my trusty voltmeter, connected the wires to my voltmeter to check continuity. when i would turn the transmitter on i would get continuity, when i would set it to off i would lose continuity. so it appears the thermostat was working properly. i then plugged the thermostat back into the stove and still the same problem.
i decided to plug the voltmeter in line with the thermostat to see if i would lose continuity. wires go from the jumper on the control board, then to the lead on the voltmeter, then the other lead goes to the thermostat, then the other lead of the thermostat goes to the other jumper on the control board. tested the on/off function of the reciever and the stove started turning on and off properly.
so obviously this is a very temporary setup but i don't know what i need to do to make it a permanent solution. i am not an electrician by no means but i need to get this working with this thermostat. anybody have any suggestions?
sorry about the lengthy description, just wanted to be detailed
Shawn Trout
Shawn Trout
