Hi everyone,
After determining the auger motor on my Whitfield Advantage II T stove needed replacement and when I disconnected auger motor wires, prior to disconnect power (yes I know, I should have confirmed power was off) I shorted them to ground causing 6 amp fuse on circuit board to blow.
Upon installation of new auger motor and replacement of fuse, I turned power on and noticed that auger motor runs constenly regarless if auger on / off switch is on or off. When switch is on indicator light blinks normally.
Could circuit board have been damaged although I see no evidence of anything wrong.
Any and all comments appriciated.
