White scale on connection
BigJ273
718
Maryland
I have two copper pipes that come out of my boiler. I know nothing about this stuff. There was a build up of white crud around the connections. Pics attached. The pics are after I cleaned some of it off. Is this something I should be concerned about or is this normal over time? The boiler is at least 25 years old. No visible water leaks, however this area is very hot, so I imagine a small leak would instantly evaporate
White scale on connection White scale on connection
I had the same kind of thing on my old water heater that was already in this house when I bought it, and the 20+ years since...never caused an issue, never actually saw it "wet", even though I always assumed it was from a minute leak...
If that is residue from leaking water, it may have closed already because of said residue...
When I was a plumber you’d see this all the time it is just years of build up from the copper pipe and flux and electrolysis really nothing to worry about. You’d see puddles of water if their was a leak. If it’s more of and eye sore than anything just take a wire brush and it should come right off for you.
Thanks brother! I greatly appreciate it
Reactions: Rockstar1346
