Hello
This has been happening intermittently on our 2007 Toyota Camry 4 Cylinder 4 Door Sedan. If I stop and turn the car off with the key and then turn the car back on then it is fine for a while?? See Yellow arrows in Pic Below - click to Enlarge.
At first, I did not see the brake and ABS lights so I put in a new speed sensor. This car has one sensor in the top of the transmission under the air filter box. It is just held in by one bolt.
That did not fix it so I called the Toyota Dealer
He said to get the VIN number on top of the left side dash board.
VIN
4T1BE46K47U620794
Then I saw on the web that if the 5th digit is E or K, in my case E then it means the ABS Control Module has the skid control option and this brand new part to fix the problem is $2100 and takes a few days to get![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
There are 4 E-5 Head star bolts holding the module and a lever that pulls up to disconnect the Ziff connector on the side of the module.
On this car the brake lines do not go directly into the black electronic part so replacing this part is just plug and play!!
The Auto Parts stores sell the part for between $400 - $600 plus $200 core charge and the rebuilders can repair it for $150 or sell a rebuilt one for $190??
Anyone have this issue?
This video seems helpful
Pic 1 - Shows dash board problem
Tachometer going but speedometer dead and brake light and ABS light both on???
Pic 2 - Driver’s side of engine
Pic 3 - ABS modulator
Pic 4 - Black ABS modulator Control. See star bolts.
Pic 5 - Rebuilt module
VIN
4T1BE46K47U620794
