which would you choose
ailanthus
390
Shen Valley, VA
I met a tree guy that has a processing area about a mile from me. I can pick up some relatively easy shoulder season wood. Which offer would you take and why?
1. Pine slab wood. About 3x7x14 ft dump load. Avg thickness 3", mostly with bark. $75 delivered.
2. Ailanthus, about 4.5x7x12 log load. $225 delivered.
I've burned both types of wood, but never slab wood. I'm leaning toward some pine because I've had little time to scrounge lately. I also hate burning my oak & BL in anything but the coldest weather.
Discuss.
Never burned ailanthus . . . but I do burn whatever "junk" wood I happen to have on hand in the fall and spring. This year . . . as in other years . . . eastern white pine is on the menu. I also have burned softwood slabs in the past during the shoulder season . . . also makes good kindling or wood for those early morning restarts.
Reactions: Osagebndr
It's so much work to process wood, and time is short. I wouldn't take either. Time spent processing pine is time I could spend processing ash or oak. Free firewood is far more plentiful than free time, at least around here.
Pine slabs-.cheaper, easier to procees than the logs,I would think. Also partially dried in slabs?
How does ailainthus burn? Similar to pine?
Probably similar, it's very light when dry and doesn't coal at all. Good point about the processing, most of the pine would only need to be split once, if at all.
Drove near ya today on 11- guy by the Lacy elementary school has some monster rounds (5'.across?) Any idea what those are?
If I were 6 years ahead like you are, I'm not sure I would spend money on ailanthus. You can afford to be a bit more selective if you choose. As for the pine, that slab would should be fairly dry. It will burn hot and fast. I used to get a pick-up truck load of slabs every few years to use for kindling/campfires. I personally would not buy either, but I did like the slabs because they did not have to be split and were really easy to process and stack.
Not sure, I'll have to check it out next time I'm by there.
LOL, after last year, I feel like I'm only 3 years ahead, & I know I won't have much time to go cut this winter. I'm still thinking about the pine, but we'll see...
