Beech shows higher in btu rating , however speaking from experience burns with red oak are considerably longer, I know this well as I'm sitting on 25 cords of red oak and 5 of beech, and have considerable experience burning both, either one is outstanding as heat producing goes.Beech is higher BTU I think, but I like Red Oak for decent BTU and fairly easily splitting. Vast majority of what I get here is dead Red. I've seen Beech in eastern So. IN, but not many here...maybe one I thought I saw, but couldn't stop to check it out. Don't know how it splits.
Now, White Oak BTU would be approaching that of Beech.
Im a HUGE fan of red oak now! I found a stash of red oak buried behind mixed stuff, and have been having a great experience with red oak. I want nothing else now. Long, even, predictable heat.wich should i choose beech or red oak?
Im surprised to see Red Oak so far down the list next to White Ash.Not buying that Red and White Oak have the same BTU, based on my experience with both.
This list is more in line with what I've seen here, but I haven't burned all of these species. I've also seen a lot of lists with these number and only a couple that claim White Oak is 24 MBTU. One anomaly is Douglas Fir; Numbers all over the board, and I have never burned it so I have no idea..
Choosing Firewood - BTU Content by Species
The quality of your firewood directly affects heat output, duration of burn and performance of your stove. Softwoods generally burn hotter and faster, while hardwoods burn longer and produce better coals. Density and moisture content are two critical factors to consider when purchasing wood for...midwesthearth.com
Come on man...lol. You can eyeball the different between 25.7 and 24 million BTU per cord? More power to you.Not buying that Red and White Oak have the same BTU, based on my experience with both.
thats the problem i have but if there was a significant difference in heating i could skip a season of burning to season it. i'll go with beechRed oak is very slow to dry, I live in a small city and storage is a problem so I don’t have time to dry red oak.
Yep, seasoning time and splitting ease are in the equation when deciding between woods.24 (red oak) vs 25.7 (Beech) MBTU per cord is not something easily noticed when burning. (Is blue beech really a beech?).
As mentioned above, seasoning time is where the advantage of beech is.
In testing the BTU figures I find online, the only thing I "eyeball" is the clock on the wall--My stove temp/cat glow over time, and the amount of wood left in the box over time. I also "arm-ball" the weights of various woods when they are thoroughly dried, since BTU generally corresponds to wood density.Come on man...lol. You can eyeball the different between 25.7 and 24 million BTU per cord? More power to you.
Either list is fine with me, the point is still the same: beech and oak have about the same BTU value. Beech may be slightly more depending on the species
"Copper Beech" appears to be the European version but I haven't checked into that enough to say for sure.It actually depends on which beech were speaking of.. I get copper Beech....ifs is choice between a 24 million BTU wood and a 28million BTU wood I go 28 million btu wood for the same amount of work.. if its only a different of a million.. that doesn't really make a difference to me.. it will go either way..
Maybe good from a drying standpoint, but how does it split? Depending what specie it actually is, drying may be slower and splitting might be tough unless you use a hydro splitter.thats the problem i have but if there was a significant difference in heating i could skip a season of burning to season it. i'll go with beech
I say go with both you cant really go wrong
