Which Jotul: C450 Kennebec or C550 CB Rockland?
tomWright
42
N. New Jersey
OK, so after NOT being able to install an insert last year, due to reverberations in my bank account from doing an emergency switch from oil to natural gas, with decommissioning of my oil tank as well in Nov 2008, I am now getting an insert this winter. I have settled on Jotul, as they are my preferred brand of the ones the local shop I am using carries. The shop has a good rep, and they seem like decent sorts. I do have an alternative shop to use if this does not work out.
The installer for local shop just left after doing a cleaning, inspection with camera and measuring. So I know I can fit either the C450 or the C550 in the fireplace.
The chimney has cracks in the liner, and the top flue tile is about to fail, so I need a relining no matter what. they are recommending straight pipe rather than flex, to avoid new tiles or other expensive options. Since they do not usually stock this, they need to get back to me on a price. Luckily, the chimney is a straight run, so it should be easy.
My choice is really which Jotul to get. I like the flush-fit look, and was hoping to get an Outside Air Kit as well.
I prefer the flush look of the 550, but I wonder if it might be too big for my house, plus it does not seem to have provision for an OAK. Does anyone know for sure? The installer said it did not, and I tend to think he was correct.
The C450 is OK looking, and it has provision for an OAK. BUT I only have 20 inches of brick hearth to work with, (also 5.25 inches raised above the floor), so the minimum 2.5 inches the C450 projects from the face of the FP is cutting the clearances close. I would like to avoid a hearth pad, I do not have a lot of space in this house, plus the ones I have seen are butt-ugly.
The house is a 1500 sq. ft. ranch, 'L' shaped, with the fireplace in the living-room at the end of the long leg of the 'L'. If you turn with your back to the fireplace, the dining room is to the right through a 10 foot wide walk-through, and the kitchen is an extension of that forward to your right. So the LR, DR and K take up that part of the L. There is a small door way from the K back into the LR at the far end. So air circulation is good through these rooms.
At the far end right side of the LR is a short hallway, (7 ft), going straight back, Bath is off that to the right, (shares a wall with the K), basement stairs across from that. Past them are two bed-room doors, so this is a straight line from the fireplace down the hall to them.
At the far end left of the LR is a short hallway, (4 ft), at right angles, this has a closet in the wall facing into the LR, and the front door facing the closet, and the master BR at the end of that. Air circulation to that is not as good. (yes, the house is poorly laid out)
The LR is about 23x11, with the DR and K added together taking up the same space as the LR.
So, will the 550 be too big? Would the 450 be big enough?
Thoughts on the OAK? (drafts thought the windows without it?)
I plan to use these mostly on the weekends as I am not always home during the week. Though when I get the hang of burning, I will use it during the week when I am at home as well.
Thoughts from the masters?
I had the Rockland installed in April and will be burning for the first time this year, so I can't give you too much advice. What I can say is that I had room in my fireplace for both and opted for the Rockland. First of all, the price difference between the two because of percentage discounts was less than $100 as I recall. Second, After having read this forum for many, many hours, the overwhelming opinion here is that if you can go bigger, do so. You can make a smaller fire in a bigger stove, but you can't make a bigger fire in a smaller stove. I am basically just repeating what many veteran wood burners here have stated. I will be learning a great deal about wood burning this winter and am looking forward to the process.
Good luck!
I have burned the C450 for two winters here in Nova Scotia, and I would it wouldn't be too small. You aren't as likely to have a good coal bed in the AM to restart the fire with, but for us it has not been an issue. You are likely to have to reload more often than with the 550 - that is a factor I enjoy, but many do not.
As for the OAK, many folks in single level homes like yours have no problems without an OAK. If you have no specific requirement for the OAK, I would recommend you choose your insert based on the other factors vice OAK alone.
I agree with Jaugust124 on the "bigger is better" mantra - longer burns and less reloads are likely with the 550 - bigger wouldn't fit in my fireplace.
Thanks guys. I am leaning toward the 550.
Will building a relatively small fire in the larger C550 still burn hot enough to allow the secondary burn to ignite?
Just a devils advocate for the 450.. the firebox is nice and square, and the avail option of single OR double door makes it work for different looks. I like the access to the fan unit, as well, for easier cleaning (althout the rockland does well, the 450 is an easier unit to remove/ reinstall said blower).
Can you describe how the 450 is easier to clean than the 550? Is it only a matter of weight or are there additional reasons?
Summit is likely refering to the fan - it sits in front, and can be vacumed easily by lifting the ash lip up. To remove it, just pull. Easy to take into the shop and blow the dust out of.
If you prefer the look of the Rockland, and it fits in your fireplace (and you can ignore the OAK), you probably have your answer. Both are good units - and while some mention the advantage of the 450 in terms of cleaning the fan, I think the fan on the 550 is likely better overall since it has a variable speed controller (the 450 only has a high/low setting). The 550 will also give you more flexibility in terms of burn time.
In case you're wondering, I do love my 450 and would buy it all over again. I don't think you would regret either unit in terms of quality but if you have preference for one over the other you should really get the one you prefer...
I have the 550 and the fan is easy to clean. Just lift up the grate under the door - it is not attached - just held in place by gravity. I don't think it could be much easier. Good luck.
One thing my installer pointed out to me about why he liked the 450 better was the ash lip. When you open the door, if any ash drops out, the ash lip
will catch it before being sucked through the fan and blown out into the room. The other doesn't have an ash lip. Also the 450 blows out plenty enough heat
for your size home.
I would go with the 550. This will be our third heating season with it and it heats the house very well. House is a ranch 2000 sq. ft. You can always build a small fire in the 550 and the variable speed fan will make the difference. It is very easy to clean, I don't have to move the stove to clean the stovepipe; my roof is easy to access. I like the single door also. I would buy it all over again.
They are both nice stoves in my opinion. We are on our third season with the 450 and we love it. The stove is installed in a large basement family room at the far end of the house with an open staircase at the opposite end. The upper level of the house is approx 1700 sf. The stove heats the house well and is not overwhelming in the family room which is important to us. Anything larger would have probably run us out of the room that the stove is located in. We generally have a good bed of coals in the morning and the fan is still blowing after an all night burn with good hardwood.
This will be my second season burning with the C550 and let me tell you this stove puts out some serious heat!!! I have a 2700 sq ft colonial with 10 foot ceilings down stairs. The stove will heat my entire house except on the coldest of winter nights. I actually stayed up all night once on a -20f night just feeding the stove keeping it at max operating temperature to see what she could do. She was able to keep my house at 66 degrees the whole night!! maintaining a 90 degree temperature gradient in a house this size is unbelievable! I'm very happy with this stove!! I will say however that these stoves like to burn. they are designed to burn efficiently and in order to do this they have to have air. Thats why Jotul has limited how much you can damp her down. I hear about so many people adulterating the dampers on these stoves but all they are doing is voiding their warranty and creating a less efficient appliance. Your decision between the Rockland or the Kennebec should be solely based on the size of the space you wish to heat with it. You don't want to find yourself in a situation where you have a Jotul insert that is too big for your house because your going to constantly be trying to damp it down and it will heat you out of the house.
Hope This Helps!!!
OK, well I went with the 550. It was installed this past Thursday and I am on the third break-in burn right now. First burn was started by the installers, just kindling that lasted about an hours, second was me the next day, kindling and a small split that lasted about two hours. This one, I am feeding it a log at a time, I want this one to last a few hours at a lower heat to drive off as many of the fumes form paint curing as I can get. Then tomorrow I will load it up and see what happens. I am hearing a few pings and tings once in a while as it settles in.
I was trying to embed images, but this does not seem to work for me here. Preview here is not showing them whether I use the IMG button or try coding an img tag myself.
So, As thanks for all the help you folks on the board gave me over the past couple years as I dithered and delayed, I have uploaded some stove-porn to Flickr:
http://www.flickr.com/photos/89243177@N00/sets/72157625147814307/
You will see the chimney flue, in its scary condition. The installer was able to break the flue tile with his fingers.
You will see before and after pics of the chimney and the install.
Yep, that top chimney tile is spalling pretty badly and will need to be replaced soon. It doesn't look like it is going to be weathertight for long. The stove looks great. In the heating season, once the insert is cruising nicely, try the fan trick of blowing the cool air towards the stove room. It should help a lot.
I grabbed a screenshot of the stove from Flicker. Here are the instructions for posting shots on the forum:
https://www.hearth.com/econtent/index.php/wiki/How_to_Upload_Images_to_Forum/
https://www.hearth.com/econtent/index.php/forums/viewannounce/27_2/
It you still need help posting, just ask.
  • Which Jotul: C450 Kennebec or C550 CB Rockland?
Thanks BeGreen.
The top flue tile was removed when they did the reline as part of the stove install. It probably would have failed in the next big wind.
