Hi all. I am new to the forum. There is some great info on here. Hopefully this post/responses can help others as well. Thanks in advance for any and all help you can give. Sorry for the length of the following post but I want to be as explanatory as possible.
Growing up I had a wood stove for many years, but was never the one in charge of maintaining it or paying attention to specifics. I would just throw wood on when my parents weren't home and that was that. So now its time for me to learn. My girlfriend and I moved into our new home which has a PE Super 27 stand alone wood stove in place. Lovin it so far, seems like a good stove from what I can tell from my limited knowledge.
I have been searching and reading for days on this forum but cannot seem to find a post that is specific enough to answer my question... With a fresh load of wood, if I cannot achieve both a secondary burn and a lazy flame, is it better to aim for a secondary burn regardless of how fast I am ripping through the load of wood, or should I ignore the secondary burn and get the flame to be as "lazy" as possible as quickly as possible to prolong the burn time? I am trying to find a sweet spot between using the woods BTU's as efficiently as possible, while getting the longest burn time. I seem to have to run the primary intake open at least half way with a fresh load in order to achieve the secondary burn (which I think is normal to an extent), but doing this rips through wood quickly and severely shortens the time between reloads.
Once I achieve secondary burn, I attempt to go shut the primary intake slowly and in intervals until I get a "lazy" flame. Sometimes the "lazy" flame will hold fine and I just leave it be (although there is no secondary happening) until I can shut the primary 95 - 100% closed.... but other times the lazy flame only last for a few minutes until its not putting out any heat and it starts to smolder. I have to open the primary again to get it going. This seems to be the cycle I have been stuck doing for the first hour or so after reload (unless I just leave primary open which I don't want to do). Keep in mind I am far from okay with having to reload this stove after only 3-4 hours. I am not trying to go through that much wood. I am using wood mainly to save money and if I start going through a lot of it, it will defeat the purpose.
My regular time so far between reloads is 6-8 hours, preferably 8 - 10 if I have some good coals going and it isn't too cold out, but 10 is very very rare, almost never. I am not too concerned with the house cooling off a bit in between reloads, my girlfriend and I do not enjoy a hot house. So... how can I get the most out of a load of wood without sacrificing the reload time too much or sending too many BTUs up the chimney? Would I be better off leaving the primary open for an extended period of time during the beginning portion of the burn to achieve secondary burn and burning the load that much faster? Or should I try to get to a lazy flame as fast as possible, ignore the secondary burn, thus increasing the burn/reload time by a couple/few hours? I do understand the secondary burn represents unused energy/gas, so by seeing secondaries it is the most efficient burn, but to achieve that I am losing overall burn time and reload time. I feel like my obsession with trying to prolong burn time/reload times in an attempt to use as little wood as possible, is causing me to waste a lot of the first hour of my burn. Unless prolonging burn time provides more benefit than secondary burn?
I am willing to sacrifice a 1/2 hour or so between reload times if it means not babysitting this stove and adjusting air intake constantly for the first hour. Once an hour or two has past, I can shut the air intake 95%-100% and get a lazy flame with a secondary burn for a little bit, and then a nice lazy flame putting off good heat for hours after that. The issue/question I have above applies to the first hour or two after a fresh reload, as I can't find a good in-between, between having the stove ripping hot, and prolonging the burn time as much as possible. The moisture content of wood I am using is between 12 - 17%. I do not know any other specs on the stove unfortunately.
Previous owner of the home did not have temp gauge installed on the flue and no stove top temp gauge either. Maybe I am not achieving a hot enough temp before closing primary? I am reading peoples posts on here saying after they reload with seasoned wood and a good bed of coals, they let the primary rip wide open for 5-15 minutes give or take, shut the primary down completely, and then have a nice lazy flame with secondaries without issue. Do I have to choose between either a secondary burn or a lazy flame for the first hour or two, or is there an in-between? Is there even such thing as being able to have a secondary burn with a lazy flame for the first hour or two after fresh reload, or is this not achievable until most of the gases have burned away after a couple of hours? Is it okay to adjust primary until there is a lazy flame for the first portion of the burn, or is this wasting mass amounts of BTU's by not getting to secondaries? Achieving longest burn time is my absolute priority, but not if I am wasting that much potential energy, and not if there is a better way that shortens the burn cycle/reload time by only a little bit.
Thanks
Thanks
