I hired someone to install a wood stove with a manufactured chimney, which exits to the outdoors through a cathedral ceiling with a metal roof. Attached photos show the view from the interior after the chimney installation, before connecting the stove. My question: should I insulate this opening, and if so how?
My installer says absolutely not. He says that the space between the ceiling and the roof needs to be open to allow heat to escape from the chimney and "The little space, especially once the interior trim plate is covering the opening around the chimney pipe, will not be cooling down the home to any degree. Filling that void with insulation may create a situation that heats up the framing around it."
Looking up into the 14 x 18 opening (6" deep) you can see the bottom of the metal roofing, the wings on the roof support, the tin-snipped opening in the flashing, and above that the sloped walls of the flashing itself (it looks like daylight because the storm collar is sealed with clear silicone). My arm fits through the gap around the chimney in some spots. I see the argument for leaving air space in the void, but I strongly think I need to at least put an inch or two of Rockwool, SUSI, or similar perhaps on the flat at the top of the opening against that metal roofing/chimney flashing, to keep the rising heat in the room from conducting straight out through the metal--a situation that I imagine will be especially noticeable in the wee hours of a winter morning when the fire is down to coals and the outside temp is 10 degrees.
Even better IMO, but perhaps overkill, would be to create a retrofit sheet metal air barrier to go below the insulation, still leaving 4-5 inches of void below the sheet metal.
My installer does not approve of SUSI and says Rockwool is only fire resistant but not fireproof enough to go up against the chimney. I would welcome getting some clarity about whether I'm too paranoid about heat loss through the roof. Thanks.
![whether and how to insulate this chimney exit? whether and how to insulate this chimney exit?](https://www.hearth.com/talk/data/attachments/300/300654-e70c2760a96cd08e2a2b0623f93214dc.jpg)
![whether and how to insulate this chimney exit? whether and how to insulate this chimney exit?](https://www.hearth.com/talk/data/attachments/300/300655-9e923f11a79299304d1d25c719f09918.jpg)
![whether and how to insulate this chimney exit? whether and how to insulate this chimney exit?](https://www.hearth.com/talk/data/attachments/300/300656-ba6264a888b019244efd03bd25ed1647.jpg)
