Where to get info on a Hearthstone H1 Soapstone
ColdnVT
2
Northeast
Hi everyone, Brand new here. Looking into getting a used Hearthstone H1 woodstove. I was told this is a BIG stove and heats around 3,000 sq ft home. Does that sound correct? I have a smaller home, around 2,000 sq feet. Would this be too big?
Also, does anyone know where I can get a manuel on this? On one of the front doors it says 1979 so I'm assuming that is the year it was made??
Any help would be appreciated!!
Welcome! Based on what folks have reported, I don't think it will be too big. It's an early model and not that efficient a stove compared to the later units. Try searching on Hearthstone I (that's a capital I, or roman numeral 1) as well as Hearthstone H1. There are several discussions about the stove. Here's a good one:
https://www.hearth.com/talk/threads/9703/
Welcome. I'm not familiar with the stove, but I doubt it is oversized for 2000sq. If it was a big steel beast maybe, but the soapstone is a different kind of heat, not the searing heat you get from metal it's a more even gentle heat. If it does get too hot for you just put less wood in it. It's better to have extra heating capacity than not enough.
Model: HearthStone I
Production Dates: 1978 - 1988
Serial #:
Note: Color must be specified for cast iron parts which are available in enamel.
Key Part # Description
A 211-114A Reversible Flue Collar -Round
211-17 Flue Collar Oval No Longer Available
B 2111-01 Top Casting No Longer Available
C 91-58131 Damper Retrofit Kit (Mid 1982 & Earlier)
91-58130 Damper Retrofit Kit (Mid 1982 & Later)
D 91-58142 Baffle
E 2111-115 Reversible Flue Cover Plate
F 2111-18 Inner Flue Plate -Round
2111-18A Inner Flue Plate -Oval
G 91-58146 Secondary Air Pipe Kit
H 91-58140 Back Plate Assembly
I 2111-19 Corner Post (Side Leg)
J 91-58141 Side Plate Assembly
K 91-58148 Bottom Cast Assembly
L 2111-22 Bottom Foot (Leg)
M 2111-02A Ash Lip
N 91-58150 Front Door Top Steel w/Tab
5000-037A Front Door Bottom Steel (Not Shown)
5000-003 Side Door Steel (Not Shown)
O 91-58170 Front Door & Door Frame No Longer Available
P 91-58121 Front Door Latch Top w/o Coil Spring Handle
91-58122 Front Door Latch Bottom w/o Coil Spring Handle
Q 91-58125 Damper Handle Assembly
R 90-58000 Damper Bushing Assembly
S 91-58120 Side Door Latch w/o Coil Spring Handle
T 91-58176 Side Door & Door Frame No Longer Available
91-58101 Gasket Kit
91-58105 Glass Replacement Kit 6" x 12"
91-55809 Oval to Round Adapter
91-57101 Bottom Heat Shield
91-57105 Rear Heat Shield
91-57110 Spin Draft Retrofit Kit
91-57100 Spark Screen No Longer Available
2111-05 Front Air Channel No Longer Available
2111-06 Left Air Channel No Longer Available
2111-07 Right Air Channel No Longer Available
2111-08 Primary Air Upright No Longer Available
2111-09 Primary Air Intake No Longer Available
1 1101-01 H-I Stone 6/13/2003 H-I.xls
2A 1101-02A H-I Stone
3 1101-03 H-I Stone
4 1101-04 H-I Stone
6 1101-06 H-I Stone
7 1101-07 H-I Stone
8 1101-08 H-I Stone
13 1101-13 H-I Stone
15 1101-15 H-I Stone
17 1101-17 H-I Stone
18 1101-18 H-I Stone
6/13/2003 H-I.xls
What I need specifically is what the manufacturer requires for placement of the woodstove. How far away from walls, etc.
I PM'd you on this. I have a manual in PDF for you.
MarkG
