Where to get an EF-002 convection blower cheap?
Don2222
9,151
Salem NH
Hello
I am looking for an inexpensive convection blower. Has anyone found a cheap replacement for Enviro EF-002.
This is the one I want. Does anyone know how many CFM this is?
http://www.stove-parts-unlimited.com/Enviro_Convection_Blower_115V_p/ef-002.htm
Spec on squirrel cage blower
Fasco
No. 70218485 Type U21B 1.9A 115vac 3,000 RPM
P/N EF23
So far I came up with this Fasco 3100 RPM 135 CFM 115 vac but the holes in the flange are off.
for $96.95 with the nice dust screen!
http://www.globalindustrial.com/p/h...-Blowers-pronto_shop&infoParam.campaignId=T9R
or $98.22
Cheaper here at
http://www.cshincorporated.com/product_info.php/products_id/910
VOLTS 115
PHASE 1
RPM 3100
BRAND Fasco
MANUFACTURER PART NUMBER 50752D500
CFM HIGH 135
HERTZ (HZ) 60
AMPS 1.1
BEARING TYPE Sleeve
APPROVAL UL and CSA
  • Where to get an EF-002 convection blower cheap?
Hello
This A.O. Smith for $85.26 is a good deal too. Again the holes need to be drilled if the flange is the same size. Anyone ever try it?
http://www.amazon.com/Smith-9492-Shaded-Centrifugal-Blower/dp/B007ATNCWC
Product Features
  • 140 CFM
  • 3000 RPM
  • 115 volts
Product Specifications
Part Number
9492
Item Package Quantity
1
Item Dimensions
Length
9.50 inches
Width
8 inches
Height
8.50 inches
Product Description
Centrifugal Blower, Shaded Pole, OAO Enclosure, 1 amp, 60 hertz, Sleeve BearingReplaces: Grainger 4C442, Fasco 50752-D500.
Product Details
  • Product Dimensions: 9.5 x 8 x 8.5 inches
  • Shipping Weight: 6.3 pounds (View shipping rates and policies)
  • Shipping: This item is also available for shipping to select countries outside the U.S.
  • Shipping Advisory: This item must be shipped separately from other items in your order. Additional shipping charges will not apply.
  • ASIN: B007ATNCWC
  • Item model number: 9492
Looks good but I do not want to go with used.
I just found this new one with the exact same size mounting flange! Says it will replace Sherwood Enviro! Ah Ha!
This Brand New Fasco B24220 for $75.65 is nice and cheap!
http://www.cshincorporated.com/product_info.php/products_id/4053
B24220 Transflo Blowers
115 Volts
1 speed
50/60 frequency
2600 RPM @ free air
1.3 amps @ free air
135 CFM.
Cross References: ARP Industries 7021-8579, National steel 7021-10794, Pyro 7021-7462, Sherwood (enviro) 7021-7582, 7021-8249, 7021-7938, 7021-8711 7021-7761 7021-7758 7121-7758
Hello
Back to the drawing board.
The blower in the last post is the exact same size. The mounting holes and the flange was the exact same.
However the motor is on the right side and should be on the left side to fit into the EF-2 ! ! !
Here is a thread with pics and info
https://www.hearth.com/talk/threads/enviro-ef2-blower-motor-problems.74342/#983298
This looks like it will fit but not cheap at $147.09
http://www.cshincorporated.com/product_info.php/products_id/169
  • 1/35 HP
  • 115 Volt
  • 3000 RPM
  • 1.5 Amp
  • Shaded Pole Motor
  • Open Construction
  • Sleeve Bearing
  • Rotation: CW Opposite Shaft End (CCW Shaft End)
  • Body Length: 7.3"
  • Motor Frame Diameter: 3.3"
  • Square Discharge, Square Flange and Plug
  • Flange Dimensions (In.): 4-3/8 x 4
  • Bolt Hole Center to Center (In.): 3-3/4 x 3-1/2
  • OEM Convection Blower Assembly - Replaces Fasco 7021-7786, 7021-9854, Whitfield 12126109
Any suggestions?
