hi, i just got a 3CB, the blue enamel one, looks great. i'd like to put a OAK on it be where would i connect it? there's nothing in the manual but they do seem to sell kits online but no instructions where it goes on the stove. thanks
There is no outside air connection for this stove. That is one of the reasons it is not permitted for mobile home use. The air enters in different locations for the air wash, the startup air and the secondary air.
Outside air adapter for the F3, 3CB, and F3cb can be ordered directly from Jotul through woodmans.
Part number-156408 -Outside air adapter
I am not sure what it takes to install it, you will have to get the rear heat shield off and possibly have to remove the cover for the secondary air hole, which would be a single bolt going through the stove and baffle on the inside rear wall.
I see that part is listed a general one that covers many old models like the 118, 602, 100, F3 etc.It's listed as a passive air adapter. It can't direct connect to the spin draft air control on the old stoves and the F3CB has multiple locations where air enters the firebox. Does it just duct fresh air in the general vicinity of the intakes? Note that this part is not mobile home approved according to one seller.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
