First Step buy this book,
https://www.dummies.com/store/produ...Dummies-2nd-Edition.productCd-0470596783.html there is free download of the first editions somewhere but I could not find it quickly.
Next step go to this site
http://www.dsireusa.org/ and see what incentives are available and see if net metering is available. In some cases smaller utilities don't want solar on their system and have policies in place to discourage it. If you are one of those areas it makes things far less attractive.
Do both of these things before you talk to a salesmen. Be aware that many folks selling solar are commission based and could give a darn about what happens after you have signed a very complex legal document. In the vast majority of cases, if you cant pay for and own a system you are handing over much of the profits and taking on a lot of long term liabilities if you do creative financing like a lease. FYI , the 30% federal solar rebate is dropping to 28% next year. Some installers are hyping the end of the 30% as the "end of the rebate", don't be pressured as the 2% could easily be eaten up by rushing.
Next step determine if your local building inspector will allow a DIY installation and if you have to go the full code route. If you need to follow code its harder to DIY but not impossible. I have no commercial interest in this firm but they sell what looks to be a pretty complete code compliant kits
https://www.altestore.com/store/solar-power-systems-c447/. If you have read the book you will have calculated your system size so this will get you a rough idea on system cost, but the ideal system will vary depending on incentives.
Ideally depending on your potential system size you may want the electrician to put in a main panel with extra bus capacity. They may have to install a 250 AMP bus panel with a 200 AMP main breaker if your system size is much over 5 KW. That saves having to do a line side tap which is far more expensive and potentially uglier. There is no need for an extra conduit to the utility pole, the solar ties into the main panel and feeds power into the panel, if you are using more power than generated the utility measures that on one channel of the meter and if you are generating more than you need they record it on second channel of the same meter. You most likely need a spare conduit through the wall from the location of the inverter or gateway to the outside of the house near the meter. You may need a rapid shut down switch mounted next to the meter. You may not depending on the type of system you install but spare conduit is always a nice thing to have.
You may want to run a metal conduit from where you plan to install the inverter or the gateway to the attic when you are doing the rough in so you don't have to run wiring outside the house. This have to be metal conduit, plastic is not acceptable.
Put a whole house surge suppression device on your main panel. This protects the house from surges from the power line. Solar inverters tend to be sensitive to outside surges. I recommend one of these
https://www.altestore.com/store/enc...solar-surge-protection-device-300v-ac-p11543/
I have DIYs three arrays with a major rebuild of one of them. I have done all three completely solo with no help including rigging panels on the roof. Its not rocket science mostly plug and play especially if you are using commercial racking. 90% is grunt work following the manufacturers instructions , the 5% is where its worth working with an electrician as the tie into the panel requires some electrical knowledge. The biggest risk is working on the roof in the sun, its easy to get dehydrated and dizzy which is not a good combination while working on roof
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
. I timed my work for early morning or evening so I didn't get scorched.
