Hello
It will be 0 Deg F tonight and the wind here is 10 MPH, which gives a windchill of - 10 deg F (Minus 10 Deg F)
What heat setting will you use on your pellet stove for this temp?
I will be using Heat setting 5 out of 6 when it reaches zero and if it stays there a while of goes below then I may be using 6 !
This will heat the 2k split with the pellet stove installed in the basement.
The chart below shows the Pellet Stove Heat Settings we use with the Air Restrictor on 2, and the Convection Fan on 6 (Highest)
Outside Wind Speed
Temp (F) +or-5 MPH
+or-5 5 10 20
Degrees
00 4 5 6
10 3 4 5
20 2 3 4
30 1 2 3
Astoria Heat Setting (1-6)
Heat Burn
Setting Rate (Lbs/Hour)
1 1.7
2 2.46
3 3.22
4 3.98
5 4.74
6 5.5
Outside Wind Speed
Temp (F) +or-5 MPH
+or-5 5 10 20
Degrees
00 4 5 6
10 3 4 5
20 2 3 4
30 1 2 3
Heat Burn
1 1.7
2 2.46
3 3.22
4 3.98
5 4.74
6 5.5
