Hello thanks for the input and access to your diagram of how your system is set up. The marathon wood boiler I have was set up and running like how the diagram displayed. How it worked as it was discribed to me.
No zone calling for heat.
If the temperature in the wood boiler is lower than the oil boilers low burner turn on temp the wood boiler loop circulator pump is off.
If the temperature in the wood boiler is higher than the oil boiler's low burner tur on tem the wood boiler loop circulator pump is turned on.
This cycles the heated water in the wood boiler down and into the SUPPLY pipe of the oil boiler and around, in a reverse cycle that water normally cycles through the oil boiler.
A heat zone calling for heat and water is hotter in wood boiler than oil boiler.
When this happens the flow of heated water through the oil boiler will reverse and heated water from both the oil and wood boiler will go up through the calling zone. THen the return from the zone will come back and into both the oil and wood boiler.
Im very new to this and I understand this is a simplified installation compared to others, I am going to incorporate a heated return path so that the return into the wood boiler is not as cold and hopefully will lessen/prevent condensation in the wood boiler as Ive been told this is a source of moisture and rusting.
I still have the open question of whether or not a zone circulator pump acts as a zone vave and when its off if no water can flow through if pushed by another circulator pump (the loop circulator)
Another simple design but alittle more complicated is the setup used by NewYorkBoilers. Its diagram is here at the bottom of this PDF
(broken link removed to http://www.newyorkerboiler.com/pdf/WC%20FuelSaver.pdf)
This diagram has some icons that are not labeled and I wasnt sure what some were, the circles on the pipes besides the boilers with an arrow below them im assuming is a backflow preventer?? On top of the fuelsaver boiler is a black circle with a white square in it, Im guessing thats the circulator pump?
THanks
~ Phil
I really don't see any reason for flowing through an unfired boiler regardless of the direction. A portion of your energy will just go up the flue pipe. It is very easy to pipe those so that there is never flow through the unfired one. I'm not sure why manufacturers continue to ignore that simple piping change?? Guess it's not their wood or oil to waste
But you REALLY don't want the oil fired boiler running heat through the un-fired wood boiler, as it becomes more of a cooling tower at that point.
If the two circs are in series the internal check will not stop flow, nor would you want it too. If the two circs pipe off a common pipe the checks prevent backwards flow.
hr
Thanks.
