NewtownPA said:
What is the purpose of knowing the flue temp?
Creosote forms when the exhaust from your stove is too cool. You won't know if its too cool unless you measure it! Now I know the next question is what temp is too cool - that can be a tough question, a lot depends on outside temp and the particulars of your chimney (how long, what its made of, how much is inside vs. outside, etc.) But a general rule of thumb that I've heard is that creosote will form quicky when flue temp is below 400, most of it will form where the chimney exits the house (the exhaust gas is rapidly cooled at that spot). Burning dry wood, and burning hot, will prevent creosote buildup, burning REALLY hot will burn creosote buildup right out of the chimney (i.e. a chimney fire - which used to be recommended, not so much anymore, so jury is kind of out on that today).
At any rate, if your exhaust gas isn't hot during the main burn phase of your fires, then your secondary combustion isn't active, which means you are not properly operating your stove (which is not only dangerous, but also an annoyance to anyone that is breathing your smoke). So the probe thermometer can be used as an indicator of proper stove operation. I don't really know the figures for other stoves, but with mine the flue gasses generally have to be over 500 for secondary combustion to be taking place, but often it runs closer to 800, and can go as high as 1000 without overfiring. 1000 is also enough to burn out any creosote in my chimney. Those figures are all specific to my own stove though, yours could be different.
You can find almost any stove manual online these days, if you do not have a copy of yours, I would get a copy and read it:
(broken link removed to http://www.avalonstoves.com/tween.asp?pdf=100-01140.pdf)
