I'm installing a 1980s Resolute on a wood floor and can't find anything in the original manual that specifies a recommended R rating for the stoveboard or hearth pad. I'd prefer not to buy a readymade tile hearth because I don't like the look and they're expensive. The black stoveboards (e.g., Imperial) are also unattractive, and a high-quality one--thicker than the typical hardware store type--sized 46x48 is $225 at my local stove shop. The DIY solution I've been told is to make a "sandwich" of materials such as Micore, Durock, and sheet metal. In what order would these materials be put down? I may tile or lay stone some day so would prefer the Durock on top, but I think the manual specifies the sheet metal on top (which sounds like it would be unattractive and get dented). Another post had aluminum flashing between the layers of Durock to "spread out the heat"(?). Could I get a cheaper black stoveboard and put the legs on bricks? I've located a bottom heat shield that supposedly fits my model stove, but don't see why I should need it if the hearth is adequate. Is there any difference between the old stoves and new certified models in how hot the bottoms get?
