What's code on wiring up an add-on?
jdew1920
52
Michigan
Anybody know what code requires for running power to an add-on furnace? Can you use the same circuit as the main furnace, does it requre its own circuit or can I tap into another existing circuit?
I believe that since they both wont be running at the same time you can wire them together on the same circuit with no problem. That's how we ran mine and I do believe that it is up to code...at least here in Michigan, your area may vary.
It depends upon the inspector. They like to see dedicated circuits for equipment for service reasons. Other than that as long as the amperage of both units together does not go over the rated amperage of the wire or the breaker.
