tradergordo said:Definitely go with the non-cat model. Good reviews, and nothing to replace. The cats have to be replaced every few years for around $300 and just give you aggrevation and extra work. WHat's the point?
See
(broken link removed to http://www.chimneysweeponline.com/hocats.htm)
Best price for large size non-cat Dutchwest (model#2479) I could find was $1139 from here:
http://www.lehmans.com/
MountainStoveGuy said:Here we go again, lets not hijack this thread on cat vs non cat, but this comment is relevent now to this thread. For what its worth, i have never sold a set of burn tubes the 10 years i have been in this biz, not one time, either im about to get a big run on them or they dont wear out around here.
BrotherBart said:MountainStoveGuy said:Here we go again, lets not hijack this thread on cat vs non cat, but this comment is relevent now to this thread. For what its worth, i have never sold a set of burn tubes the 10 years i have been in this biz, not one time, either im about to get a big run on them or they dont wear out around here.
The coriolis effect inside the tubes make them last a long time.
Todd said:tradergordo said:Definitely go with the non-cat model. Good reviews, and nothing to replace. The cats have to be replaced every few years for around $300 and just give you aggrevation and extra work. WHat's the point?
See
Don't believe everything you read. It's more like every 4-6 years at $100 if you burn properly. You also get longer slow burns with more heat and burn less wood. I definitely like my cat better than my non cat.
Todd said:Tradergordo,
You are comparing the large noncat Dutchwest to actually the Medium cat Dutchwest. The non cats are listed as small, medium, and large. The cat models are small, large, extra large. So if you want to compare apples to apples, compare the large non cat with the extra large cat. The numbers are pretty simular, maybe a little better for the cat model. The big number, 74% efficiency cat model verses 63% non cat.
tradergordo said:Todd said:Tradergordo,
I don't think so Todd, but I could be wrong. The large cat seems to compare with the large non-cat. For example, the extra large cat takes 25" logs and has an 8 inch flue collar - this is CLEARLY NOT similar to the others. The large size in both styles has an 6 inch flue collar. The large non-cat takes 22-24 inch logs. I tried to find the firebox capacity on both but I don't see them listed for both, tried to find overall weight, which I also can't find for both
As for the stated efficiency ratings - these are meaningless EPA default rates, which is why I didn't include them. If you don't believe me, do some searching. If you look at the EPA documentation, you will see that ALL non-cat woodstoves are listed at 63% efficient for every manufacturer. I don't really know why they do this, but it certainly adds to the confusion.
See:
(broken link removed to http://www.epa.gov/oecaerth/resources/publications/monitoring/caa/woodstoves/certifiedwood.pdf)
Todd said:Yes, the EPA rates all non cats at 63%, but they also list cat stoves at 72%. Seems to me cats are a little more efficient according to their test. I know there are other test labs out there, but they are bias to the manufactures to make their numbers more attractive to the buyer. They are both sweet looking stoves and I'm sure either will do the job.
Todd said:According to the VC site Shane is right. The non cat Encore is .7 grams, and the cat Defiant is .8 grams. Wow, those are low emmisions.
