![What wood stove can I fit on this pad? What wood stove can I fit on this pad?](https://www.hearth.com/talk/data/attachments/190/190179-b25c5e8cdcfdad8e949c2987b6eb8a99.jpg)
![What wood stove can I fit on this pad? What wood stove can I fit on this pad?](https://www.hearth.com/talk/data/attachments/190/190180-b3c44138492663dd35423590da8e7ced.jpg)
![What wood stove can I fit on this pad? What wood stove can I fit on this pad?](https://www.hearth.com/talk/data/attachments/190/190181-3a9b425aaebb3c2b48dc6eb071ce3f38.jpg)
New poster here, trying to learn as fast as I can. Trying to decide what stove to buy and getting confused by the clearance requirements. I'll try give as much relevant information as possible. I live in an old drafty farmhouse with a particularly drafty basement. The basement is 30X40' and the first floor the same. The chimney is 9X9" ID brick that will need about 32 feet of liner, but that's a subject for another post.
There is an old Ashley wood stove set up in the basement that needs to be replaced. It sits on an existing brick pad with a brick back wall. The current stove is rear venting. The vent center is 28" above the pad. The rear of the pad is 75" wide. It comes forward full width for 25 inches, and then angles in toward the center. The front of the pad is 50 inches wide and 37 inches deep. The floor underneath the pad is concrete so we can cut away a few inches of carpet and just leave exposed concrete for the clearances. The stove itself needs to stay on the existing brick. The back wall is 4" of brick laid 47" high. Behind the brick is drywall and wood studs. I'll try to attach pictures that will hopefully make more sense. Is that rear wall considered non-combustible, how close can I get to it with either of the following stoves?
I would like to get a Woodstock Absolute Steel hybrid, but it doesn't look like the clearances will fit. The Englander 13-nc should fit but I don't know if it can do overnight burns. I don't need a roaring fire still going in the morning, but I do need enough coals left to easily restart the fire after 10 hours. For any of the top venting stoves I'll need to cut in a new wall thimble above the brick. Doable, but not desirable.
Most of my firewood is cut 18-22 inches, I don't have much seasoned firewood under 18 inches. Certainly I can cut more ash, mulberry, and elm to whatever length, but that's not useful for this year. It doesn't seem as if there are any modern stoves that can take 22 wood that will fit in my space.
I took a lot of pictures so I can easily post what ever anyone wants to see. The main question is what stove can I fit on that pad without extensive remodeling. and that will have enough coals to restart with splits after 10 hours.
