We are in the process of buying our neighbor's house and are wondering what to expect when we get the house inspected. He installed a Jotul 3CB in the following way:
He ran a stainless steel 316Ti liner down the center of the 8" diameter metal chimney. He then connected it to an 90degree connector and to the enameled stovepipe. He sealed the flue area with sheet metal and poured a vermiculite insulation mix around the liner, and then also in the space between the 8" chimney and 12" pipe around it. Finally, he had a friend of ours (a mason) put a new face on the fireplace and brick up the fireplace except for the hole in the middle (back facing flue collar).
He has used the stove all winter for 3 years and it accumulates very little creosote -- by the way, you can probably tell I trust the guy. He's been very up front about this being a rather unorthodox install (and he doesn't get annoyed if you forget to bring his tools back).
But, the questions:
If it's in violation of our local codes (it doesn't seem to be by my reading of the code), what happens then? I'd rather not get this guy in any trouble. Will it "pass" the home inspection? If not, will the inspector inform the local building inspectors? Because of my wife's allergies, we probably will only rarely use it, if at all, but it looks good, so we'd like to keep the stove there.
Other thoughts?
Thanks!
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
But, the questions:
Other thoughts?
Thanks!
