I'm installing a "fireplace" boiler from New Horizons (through ebay). It is a Polish unit called Spectra.
http://www.cichewicz.com/files/1235465736/waterstove-manual.pdf
I plan to use a plate exchanger and I'm considering using the old 40 gal gas hot water heater for storage.
The fireplace side of the heat exchanger must be "open".
I have searched for an open expansion tank and cannot find anything in the USA like the "header tanks" used in the UK. Some diagrams show an "open expansion tank" that looks like a typical expansion tank (bladderless?) but I don't know how to make a closed tank "open".
The tank will be above the stove in a niche in the cathedral ceiling above a walk in closet. It appears that the tank should have a float valve to maintain the water level and be piped to accept any possible steam blow off from the top of the stove as well as for overflow. I hope someone has suggestions. I've searched and don't seem to find any particulars. In a recent post, someone used a water heater! But how does that incorporate a float valve to keep it full? Is there a commercial version of this type of tank to be found in the USA?
We also have a condensing gas boiler that I installed and radiant heat in the slab and fin style radiators in 2 bedrooms (that I plan to use as a dump zone).
Here is a diagram of a Spectra install with a boiler system. (in translation!) Notice that the upper left hand corner open expansion tank has no label? It is the mystery component.
![What to use for open expansion tank? What to use for open expansion tank?](https://www.hearth.com/talk/data/attachments/115/115567-fdf2499cf630069beb1f16a88b06cc53.jpg)
