Hey All-
I could really use some advice on how to proceed with my project. My intent is to remove the heatform fireplace and install a wood stove using alcove clearances.
I have removed the upper vents, what was left of the heatform, and the masonry smoke shelf. I didn't remove the lintel or the mantel. The upper part of the heatform was completely rusted away. The condition of the masonry seems to be pretty good. I'll need to a little repointing.
I was expecting to find lots of brick around the firebox so I could remove the taper of the firebox, increasing side clearance for the stove. Instead of brick, I found one layer of 4x7.5x14.5 concrete blocks with an air void on the other side. The blocks appear to be structural so I'm not messing with anything else until I get some advice from people that are more knowledgeable about this stuff.
Is there a way to remove these blocks to remove the firebox taper and make the opening square?
Should I go with an insert or smaller stove? We already have a stove.
I have attached some pictures and a hastily made drawing. The chimney is not built of solid brick. It's about 10' tall. Two opposing sides of the flue are brick, the other sides are the concrete block.
Thanks a ton!
-Powerlinefixer
![What to do now? (Heatform removal) What to do now? (Heatform removal)](https://www.hearth.com/talk/data/attachments/284/284084-1f1437493cb2bb2d2593ea1bd7dc1316.jpg)
Thanks a ton!
-Powerlinefixer
![What to do now? (Heatform removal) What to do now? (Heatform removal)](https://www.hearth.com/talk/data/attachments/284/284079-bea6bb5808ea7d23278dedc1997ae241.jpg)
![What to do now? (Heatform removal) What to do now? (Heatform removal)](https://www.hearth.com/talk/data/attachments/284/284080-f87b5acaad860b4d1cc932463cb4428b.jpg)
![What to do now? (Heatform removal) What to do now? (Heatform removal)](https://www.hearth.com/talk/data/attachments/284/284081-52f0bd4e0aad1f261016875f975203e9.jpg)
![What to do now? (Heatform removal) What to do now? (Heatform removal)](https://www.hearth.com/talk/data/attachments/284/284082-c0e5323157fa1ba82146e0d54e63a304.jpg)
![What to do now? (Heatform removal) What to do now? (Heatform removal)](https://www.hearth.com/talk/data/attachments/284/284083-e235b142e1269545e1ad033cba928d4a.jpg)
