Yesterday, I removed my hearth extension pad for the first time since installing my stove almost two months ago. I was surprised to see a bunch of moisture under parts of the pad, to the extent that there were drops of water, some about the size of a quarter. I thought maybe something had spilled and just got trapped under there. I cleaned up the floor and the bottom of the pad, and put everything back. Just now, about 30 hours later, with the stove running basically non-stop since, I removed the hearth pad and again there are drops of water under it! What gives? The water is cool, the hearth pad is warm to touch and so is the wood floor underneath (not excessively, just a nice radiant warmth). I can't figure this out, and it's clearly not good for the wood floor.
I bought this hearth extension pad used, so I don't know much about it, but I believe it had been stored in a garage for some time before I bought it. Here attached are pics of the beads of wood (hard to get a good pic of this), the hearth pad top and bottom (the bottom has some sort of dull aluminum foil looking material and was discolored and scratched/rusty looking on parts when I bought it), and the label on the hearth pad. Any thoughts of what this might be? Could this be coming from the pad, the floor (white oak, with polyurethane coats I believe), the air...? Any thoughts on what I should do about this? Should I put some very thin plywood below it to protect my hardwood floor?
Any help is appreciated!
![What the heck is this moisture under my hearth pad?!?! What the heck is this moisture under my hearth pad?!?!](https://www.hearth.com/talk/data/attachments/223/223992-1ad501c2d199c183ff825850b5f96b1c.jpg)
![What the heck is this moisture under my hearth pad?!?! What the heck is this moisture under my hearth pad?!?!](https://www.hearth.com/talk/data/attachments/223/223989-5064370c7e506f0dbee75812ef243fff.jpg)
![What the heck is this moisture under my hearth pad?!?! What the heck is this moisture under my hearth pad?!?!](https://www.hearth.com/talk/data/attachments/223/223990-886e4f4e4b0d7132d04093d839acd74a.jpg)
![What the heck is this moisture under my hearth pad?!?! What the heck is this moisture under my hearth pad?!?!](https://www.hearth.com/talk/data/attachments/223/223991-e1de9027049d1fa6db62fddb5467ceb9.jpg)
