Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
What temp should I expect the outside of class a chimney to get say 2' - 6' after the stove? (Assuming the stove rear vents and the chimney goes through the wall and up.) Thanks!
well my horizontal section of class A that goes through the wall gets hot enough you can't touch it for more than a second. Everything else after that section is barely warm.
I don't know that answer, however, here is what I do know. My chimney (simpson duratech class a) is straight through the middle of the house. About 7-8' above the stove it is far too hot to touch. The wall behind stays quite cool. I have since enclosed it so nothing can fall against it.
This would seem to be in the area of 300 °F , although it could probably get hotter. The key, of course, is the temp 2" away from it, which can only hit about 170......
On a direct rear exit such as that, it might even hit 400 - still, that is about 1/3 the temp of what a cherry red single wall pipe could possibly hit, and is well below the temp at which wood and most other materials combust.
Thank you everyone, your answers are helpful. In light of the temperatures, approx. less than 200 degrees, could you recommend a paint for the chimney? (We'd prefer building a chase, but a painted chimney that blends with the house colors is second best.)
Stainless can be difficult to paint because the smoothness of it.........there are actually some paints formulated just for it, but only in black to my knowledge.
Other than that, my advice is to let it weather for at least a couple months and maybe longer and then use a decent exterior metal paint like Rustoleum on it. Some of their formulations are shown on tractor engines, etc. which should be good to higher temps.
If you want to go the next step up in temp, use so-called BBQ paint, a selection is available online and at some hardware stores and home centers. Some paints are also formulated for gas vent, which again should meet the temp requirements.
