Hi all,
I've been reading through all the info here and this is my first time posting. I've never had a woodstove so a complete newbie.
We moved into an old farmhouse in southern Quebec (climate zone 6) and planning a new wood stove as part of a major renovation. We will use the stove as primary heat (with electric baseboards). It's a two storey house with an insulated (R-15) but unheated basement--we're not worried about heating the basement, just keep it above freezing. Our plan is to reinsulate the walls to about R-35 and the atticsto R50-60 as well as air seal. Main floor is 950 sq feet, pretty open, 8ft ceilings. Second floor is 450 sq ft, 8ft ceilings. We're planning on putting the stove in the middle of the main floor and also having vents into the second floor. (I've attached a rough floor plan.)
The other consideration is there was a wood furnace in the basement (condemned by the chimney sweep) hooked up to an 8" insulated chimney. This chimney is not in a good spot so we'll be moving it. Most stoves take a 6" chimney so we were thinking of installing a new one--it would be over 15', vertical. However, I saw the Blaze King 40 is 8" and that got me thinking I could reuse the 8" chimney pipe, it's still in good shape. However, I think the BK 40 might be a little big for our house.
We'd like long enough burn times to get through the night (7-8 hours) and the ability to cook a little on the stove when the power goes out. (Seems easier to cook on cast iron, but can you also cook on steel stoves?)
So, my questions are:
- Any stoves that call for an 8" chimney that wouldn't be overkill?
- Can I hook up a 6" stove to an 8" vertical chimney without a huge loss in performance?
- We're leaning towards PE Alderlea T5. Also the Drolet Escape 1800 seems like a possibility. But open to suggestions.
Thanks very much.
![What stove to buy? What stove to buy?](https://www.hearth.com/talk/data/attachments/300/300684-287774bd4480f2b3e9d7ed04658480e9.jpg)
Thanks very much.
