Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
This will give you a good idea even though the video isn't the best of quality. Most describe it as an angry flame. The height of the flame varies depending on how high you are running the stove and your feed rate.
I watched both videos and what I want to understand is how consistent the flames should be? I have a Lopi Yankee, what I see is the flames will go from very high reaching the heat exchange tubes to a smoldering pot. The stove is set to Medium/high Heat and Medium/high Fan (both in the yellow lights area on the panel for anyone who has the same stove). I know the flames do fluctuate but this seems like a lot. The damper is pulled out to just above the line between the 2 and the 3. It is a very new stove. I get a lot of brown soot on the glass door-could clean it daily. When I adjusted the airflow, I tried pulling it out more and the pellets jumped out of the pot. The way it is now I get many sparks but almost no pellets coming out of the pot. Does all of this sound correct? I guess I thought on medium the room would heat up more then it does now that the frost has arrived, the stove seems to be going constantly even though I have the thermostat set to 69 on the remote.
