I am purchasing a pellet stove fireplace insert. My question is, where is the best place to install it? Basement or 1st floor. I live in a 1200sf 2 bedroom solid brick ranch with a 1/2 finished basement. We have forced hot water heating using oil. The radiators (cast iron) on the first floor are recessed into the walls. Both the basement and 1st fl have large fireplaces. So looking to see if the basement or 1st floor is best location to install and save oil.
My original thought was to install the pellet stove on the first floor which is used more (60/40) then the basement, but I'm concerned about the piping for the radiators on the 1st fl which extend into the basement walls (brick). If I place the stove on the first floor and all goes to plan, the stove may prevent the the need for radiator heat for extended periods. Can't that lead to frozen pipes? Thus, I'm also thinking of putting the unit in the basement and avoid this concern but most advise that this will not do much to heat the rest of the house (fireplace is in the finished area) or save money. Only connection between floors is the stairway.
So please give your opinions
/BB
/BB
