E
BrotherBart said:Somebody in Bethel not using enough stove cement?
Dont know if this happened to you or if you took out the secondary burn chamber (SBC)........Some Like It Hot said:Since we have our stove and chimney "professionally" cleaned, our stove doesn't heat the house as well. The sweep was an idiot, but of course we didn't realize that until it was too late. He pushed all the gunk into the stove, did not disassemble the chimney pipe at all. We have a Hearthstone Phoenix with a chamber above the firebox where the air bends around into an area you can barely access at the top of the stove. He poked around from the front at the soot and creosote that dropped down and did who knows what. Any theories on what could have gone wrong? We took apart the chimney from the stove to the ceiling, there was gunk piled up in the pipe into the stove, so we made the idiot guy come back and actually remove the creosote/etc. However last winter the stove made the house warmer than it is doing now, our thermostat around the corners and down the hall would read 70+ when the stove was going for a while, now we never get the house as warm. We are burning similar wood and haven't done anything different with the windows or anything. We are trying to figure out what the problem is.
Eric Johnson said:I'd say that's true. We tend to focus on the stove and the chimney, but the outlet really accumulates a lot of fly ash over time. It was a messy job, but I used to disassemble the pipe and scoop out all the ash on my boiler once every couple of years, and was always surprised at how much had accumulated. Obviously, it was taking up vent space.
