I found this on a different forum and thought it might be good for those of you that thought class A chimney pipe is expensive!
This afternoon, I got the chimney for my wood stove hooked up in my garage. I started a fire in it and the garage was warmed up to about 60 degrees(it was 30 outside). While I was working on my Jeep, I noticed smoke started to lower in the garage. Sure enough, the chimney pipe had started the roof of my garage on fire and was burning its was down the wall! I ran to grab the hose, but my heart skipped a beat as I found out it was frozen! In a panic, I remembered I had a fire extinguisher in the shed, so I grabbed that, climbed a ladder, and tried putting out the fire. It kept burning, so I called 911. I ran inside and started filling one gallon pails of water. I was able to nearly get the fire out by the time the fire department got there. The damage is minimal, but several things got wet. I also have a heaping pile of insulation and wood to clean up tomorrow. I lucked out tonight since there was no wind and the fire started at the peak of the roof.
If you install a chimney, be sure to use double walled pipe, not single walled!
